cgriffin_5139
- October 11, 2005
Thanks I'm not leaving empty handed I will have a welder(lincon 350) plasma(esab 650) and other various hand tools.
Well if ya end up in the DC area, you are welcome to use the tubing bender here: ...except ya just had to go with 1.5" tube... the one die I dont have yet lol
4. 14" fox 2.0 shocks w350/450 springs (front)
I think you will find those springs to be a bit too stiff. I'm running 250/350 and I think that the other coil over rigs are in about the same neighborhood. Maybe Jefe will chime in with his rates.
I don't even think DB_1's are that stiff on his ranger.
That is correct. Note though that I ran the softer springs to get the lower ride height, so I have about 4" up and 10" down. If you're going for more even up/down ratio then 250/350 should be right. And I am debating throwing the 350 springs back in there now that its sagging.Jefe has 250/300 and he originally had 250/350 and said the spring rate was too high.
Look out here we come New Jersey!
Cool, any idea what part of Jersey you are going to end up in?
only three
