@joney A/C wise, on my Limited, those symptoms were the blend door actuator. Any position, any speed, everything worked except the cold air. I had the advantage of getting to hear the thunks in the dash before mine quit altogether. I bet if you tear into it, you'll find some thing like this.
If yours has the EATC, this part might be a touch more expensive and difficult to obtain. Otherwise, they can be had for cheap. I'd check this out before you pay somebody else to have a look at refrigerant, etc.
Hood latch, no sweat. Simply go under the dash, unscrew the hood release handle, remove the cable, and pull it with pliers or some such. Replace the cable if you want to.
