charlie's 3"BL, f-150 spacers, and shackles | Ford Explorer Forums
Charlie's_93EB
Cat 3 Hurricane Rated
Venice florida
1993 Eddie Bauer
Well i started 2 years ago. I bought a 3" Body Lift from 4 wheel Parts for $100 shipped.
And one thing after another got in the way. Well until last night I have been trying to get the front core support bolts off, so on Easter Sunday i had to work Ya. Then i get sent home early to spend time with my family. But it was too late at night. So pissed i start wrenching on the explorer. First i took off the manik brush guard, followed by the front bumper. Now i can see my rival, my nemeses the front mount Derocha said to try to a pipe wrench so a few weeks ago i got an 18" cheapo wrench from the Home Depot. after a few trys it finally grabbed and the bold came out and must have 5 degrees of angle in it. Then taking what i learned and applying it to the other front bolt took less then 10 minuets. Then i attacked the other eight bolts which took fifteen more minuets. So today my dad came over, he has only one leg, so all he was good for was to yelling at he and say i was going to kill myself when he looked up from the newspaper. His favorite phase was you need more damn wood!!!!
But any way the lift was very easy but it just needed prep work. But that is not to say i did not f-up some. But i disconnected the tranny lines, shifter/4x4 cables, all the wire harnesses, and e brake. Then with all four wheels blocked I lifted the drivers side and put in all the blocks, but the front i took out and burned up a 1/2 drill bit so we cut the treads off the metal golf tee looking thing replaced the metal cup and blocked it. I put in bolt finger tight as i went. Then i saw that i jacked the fan shroud into the fan i cut the bottom clips off and aligned the shroud then I did the same on the pass side. Going back to the shroud i bolted it in with a copper colored bracket from the kit PA 793. But Now the fan looked cracked in between two of the blades.
IS it f-up? and should be replaced? Or is it norm i and i did not see it till now?
I put in the steering connecter with red lock tight.
Then I walked around with red lock tight and pounded then home.
Hooked everything back up and started up fine and ran fine, the steering was better then i thought thou I could feel not sticking but not smooth as butter in some spots. If i was going around a corner and let go of the wheel mid turn it used to go strait, but now it does not always, i have to think to turn the wheel back to the 12 o'clock position. I only drove a mile So it might loosen up.
but i can not figure out the e bake,
i took it off the driver side body mount, and disconnected the part in the back with the spring where it turns into two wires. HELP!!!!!!!!!!!!
That is where i am. I wanted to see the rear bumper without moving it i hate it, it will be moved up and a class 3 hitch will be put on. I need to a bracket the look like a side was "Z"
to move the brush guard up and move the front bumper up. So i am 95% done.
In the next week or so i will put on the f-150 spacers, and shackles and the 33's.
I will take pic tomorrow and past them at midnight after work.
But damn i feel good.
ps i had plumber crack showing and my butt is sun burned.
Sounds like you had fun. The crack in the fan should be repaced, I mean the fan if thats not the way it's supposed to be IMO. That bad boy get loose and good buy rad.
Glad to see your getting it done.
Need Pics please, but spare us the plumbers cleavage.
well her she was this after noon, after only a 3" body lift. With no front bumper or brush guard and with out moving the rear yet.
ok well have the new shackles, i bought two sets b/c thought i needed a set pair side then i read the instructions after i painted them all.
2nd you see the old stock shackle
3rd you see the new painted shackle, i will run atleast one blot in the extra hole per side.
and here she is 3/4 the way done.
with the 33"s
and yes you can see the red painted drums :p
the rear is at 38" at the center of the fender, from 32".
The fan cracking in normal. you didnt do that with the body lift. It should be replaced though when you get a chance.
Also I dont think that is OSHA aprroved foot wear :p
Looking good
Looking good
first i do not swing my bat that way, :eek:
2nd thanks a lot
3rd if you look under the rear bumper, you can see my OSHA aprroved old wood blocks for jacking up for the shakles,
remeber kids
"safty 3rd :D"
Glad to see my old rims getting put to good use. Lookin' good man!
BTW, just a suggestion. Get a section of pipe that you can fit a 1/2 bolt though. Cut the pipe so that it will fit inbetween the shackle and bolt it down. It should kinda look like this
I I
I I
I=I
I I
I I
Looking good
If you don't loosen the fan shroud then jacking up the front will crack the fan...
You have mad a lot of progress and the "new" X is taking shape.. The feeling you get from accomplishing this is great (compared to the pit in your stomach when you get stuck on a bolt or 2 preventing any progress). Every time I look at my lifted X it brings a smile to my face :) Before being lifted it was just a plain old X with dreams of being a big dog...
