ksknapper
- December 16, 2005
- Pratt, KS
- 95 LTD
Subject: Air Ride System on my 1995 Explorer Limited. I'm getting a "Check Air Ride System" error on the on-board computer. It is currently intermittant. Comes and goes, with no regularity. Began about 2 weeks ago. Sometimes when you do a system check with the on-board computer is says its working fine or it throughs up the error or comes on while driving. I put it on the rack last weekend and checked for leaks at all the shocks, lines and connectors with soapy water. All shocks are fine, no leaks anywhere and got compressor to pump up the rear shocks. However, couldn't get the 4x4 to initiate the compressor as it says its supposed to do in the manual. Hung off the bumper while the compressor was on and it pumped up fine. All shocks sit about the same, so think there are no problems with the individual solenoids or actuators. Not really sure how the system works though. When the problem first started, the compressor came on 4 times sequencially. I'm leaning toward a compressor issue or some electrical interface between the compressor and sensors. Really don't want to replace the system if its not really necessary or if something simple is involved like a sensor. I heard that the compressors are notorious for giving up or the dryer causing problems but not sure how you eliminate possiblilities. What is the pressure that the compressor is to produce? It could be getting weak. It is 12 years old, honestly, can't believe its lasted this long. Furthermore, can you take it to a shop and get a computer diagnosis?
Thanks for any input.
Bryan
Bryan
