NWwoman
- June 1, 2010
- Colton,WA
- 2000 Exploder/2001-150
I have a 2000 Explorer Limited 125,000 miles that has been maintained well and is (has been?) in excellent mechanical and interior/exterior condition. Looks new!
Last Thursday, I went to the shop and had timing belt (correction: serpentine belt) changed. It had not broken; I was simply being pro-active.
Friday morning, I noticed a ticking sound from under the hood in the area of that belt. It was 38 degrees outside. As someone without mechanical experience and a (female) widow living alone out in the middle of nowhere, I did the sane thing -- I discounted it, attributing it to the cold.
I drove to the nearest gas station to fill her up. The station is 35 miles away. She drove perfectly up and down a 7 percent grade as well as over the gravel roads.
Saturday morning was the start of our one week of deer hunting/rifle. So I was up very early and -- after accidentally spraying my camo coat with doe estrus (can you believe?) -- I then see a check engine light come on.
Grr. If I didn't have bad luck, I'd have no luck at all!
So here's the question part, which you deserve after reading all of this jabber.
Is it possible that this solidly on check engine light is related to the replacement in the belt that they did on Thursday?
I drove with the check engine light on. Hunting must go on. lol. It drove fine, even through some very rough terrain, as well as on the highway.
I have to drive alone some 25 miles north to get to the service shop. Hoping to have a tiny clue as to what might be ailing it before I hit the road and then deal with the shop.
Thanks guys. Appreciate any help.
