diesel_s
- October 7, 2008
- Buford, Ga
- 2008 ST Limited
I can't figure this out, there is a clicking noise coming from my new motor, I got an engine with 20,000 miles on it with a warranty, had it installed, and I believe the guys did some **** wrong becuz m motor sounds funny at times. Sometimes when you start it, there is a grinding noise near the bottom rear of the motor and a clicking noise near the oil cap. Other times, there is only a slight clicking noise and a slight grinding noise, other times, only that clicking sound. One thing I did notice is that there seems to be a vacuum going through the oil cap, as in, when you loosen the oil cap, you hear air being sucked in like there is a vacuum, I dont believe it is supposed to do that. I need help.
