On my 1995 4.0 XLT with 110K miles, I have a tapping noise, it sounds like it could be one of the following things (as far as I know):
1. Loose rocker/valve needing adjustment
2. noisy, bad injector
3. leaking intake manifold
The engine isn't using any oil or coolant as far as I can tell. The mileage is so/so, but I drive kind of fast, so it's about 280-300miles/tank. The noise is most noticeable when idling, and it also sounds and feels like one of the cylinders has low compression, as it shakes a bit and you can tell at the exhaust there is a noticeable lope in the exhaust flow.
Has anyone ever had this problem, and how was it resolved? Thanks again in advance!!
Scott
95 XLT 'prerunner'
31x10.50 BFGs (RULE!)
Scott
95 XLT 'prerunner'
