Climate control | Ford Explorer Forums
Climate control
Dbrider92
Bloomington
2003 Ford Explorer V6 4WD
2003 Ford Explorer,V6 4.0 Having trouble with climate control. In the back of my vehicle it's blowing hot air out of the top vents cool air is coming out of the front any suggestions on how to fix this?
Depends. Is hot air supposed to be blowing out the front vents, or cool air blowing out the back vents at the time? Might be a blend door issue, motor or door itself broken at whichever end isn't getting the right temp output.
If it is blowing hot air and you have it set to blow cold, you may have a bad actuator in the back. There are 2 of them under the back driver side plastic quarter paneling. One controls temperature, the other controls position. Sounds like the temp actuator would be bad. There's a video on how to get to them. How to STOP THE CLICKING from rear air control (2004 Ford Explorer)
welcome to EF!
Thank you very much . I actually forgot about this post I appreciate it
Thank you so much I think you're right it's still not fixed and I forgot that I even posted this I've been so desperate
You're awesome Thank you very much for posting sorry it's late for answering I truly forgot about this post Thank all of you you guys are wonderful
