code decoding help | Ford Explorer - Ford Ranger Forums - Serious Explorations
code decoding help
X-North
Montreal
Hi I started my code and first i had the quick flash and then the codes reading start.
3 flash with 1/2 seconds between them that mean 111 i think after that 3 fast flash faster than the 111 code. and it repeat the 111 and the 3 fast flash.
Wjhat could it be?? Someone told me that on 1992 4.0 explroer theres no EGR so what could it be those 3 fast flashes ??
thank you
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
OBD Code 111 means "System checks OK".
X-North
Montreal
i know thta but why after the 1-1-1 it make 3 really fast flashes?
cjones101812
Avondale, AZ
06 Explorer EB
if i remember correctly (it's been a long time since i checked them with a jumper) the really fast flashes show you are switching from KOEO codes to Continuous.
have you done the KOER test yet??
X-North
Montreal
that dont work what you said because read what i have written..
I not done my koer tests only the koeo and cm ..and no it dont mean that i begin the cm code....4 seconds waiting is what it make when you pass from koeo to cm codes.
My part it make 3 flashes for the 111 three really fast flash and it repeat everyhting a second times the 111 and the three fast flashes. Thats why i dont understand and no one seem to understand why it make those flashes
