Awright, you asked for it! Ha!
Electricity and magnetism go hand in hand. Flowing electricity develops a magnetic field just like a permanent magnet has. The electric current flowing through motor windings creates a magnetic field. Oppositely, a changing magnetic field develops or induces a voltage in the motor windings. Since it's a
lternating current it's constantly changing, voltage is rising and falling, and
changing polarity as the change passes through zero volts. Here's how the A/C voltage looks:
A
SINE WAVE (because that's the voltage waveform produced when a generating device spins around, like an alternator). All + and - peaks produce the
equivalent of 120 volts, explained some other time. Because the voltage goes plus to minus to plus to minus constantly, the effect is like connecting a voltage to something + to -, then - to + over and over again, which means the
current reverses direction every wavelength, or cycle. CAN'T CHARGE A BATTERY WITH THAT! So, we got DIODES.
In nearly all A/C motors, the magnetic field caused by current flow "collapses" as the voltage goes towards zero (the horizontal line). Then a new field builds in the
opposite direction; if it was North to South before, then it's South to North. Until passing through zero again. This collapsing field prevents the CURRENT flow from coinciding with it's voltage, it BLOCKS current flow for a short time.
This means VOLTAGE appears, but CURRENT does not flow until a short time later. This effect is called "Phase Displacement". PD reduces ability to do work by the electric current. In a circuit having only resistance, like a light bulb, the PD is ZERO. Motors causing PD make Power Companies deliver MORE power than is actually used, as the PD wastes some.
Turns out, the capacitor causes just the opposite effect in A/C circuits; it makes the current flow BEFORE the voltage appears! IOW,
the capacitor RESISTS a change in voltage, while the motor RESISTS a change in current (amperes). This effect in motors is called INDUCTANCE, in capacitors it's CAPACITANCE.
Inductance is measured in HENRIES, capacitance in FARADS. These units are used in fancy mathematics to determine what SIZE capacitor will cancel out the effect of Phase Displacement on an electrical line. Is it important? Wallboard Manufacturing Plant I worked for in Colorado was BILLED extra for their PD! Couple hundred bucks monthly. One of my jobs was to install capacitors, to save the extra billing. Payback time was a couple of years.
