iamtmo
- May 2, 2019
- Poteau, OK
- Explorer 2014 6 Cyl
We purchased the Explorer used and received the secondary FOB not the Primary. The Secondary FOB died, new battery didn't fix etc... We now have the FOB key in the console pocket to start and run the car so that means the car is detecting it. The killer is during a recent oil change the lube shop turned on MyKey and we cannot remove it because we don't have the primary key. I know if we go through dealer we're looking at 200 to 250 for a new primary and a while back I purchased a secondary online guaranteed to work if you have a working primary. It however cannot be made to work as primary or so I have been told but can be programmed and keyed to work as secondary. Does anyone know of any other options for making a new primary other than Dealer rip-off or at least turning off MyKey. The delete option is not available and says it need the other key to perform an edit.
