aricanderson
- August 30, 2008
- tally, fl
- 04 XLT
Ok I have a 95 Explorer that I just bought and have already fixed the vaccum leak causing the air to blow through the vents again. Now I noticed that the ac is not cold, nor is the ac compressor cycling on or off, or the engine reving up. I took the pressure readings today and got 50psi on the low and high side. So I took a jumper and shorted the cycle switch and the compressor kicked on and the low pressure side started pulling a vaccuum. No my question is do I need to replace the cycle switch or do I need to vac the lines and charge the system with new freon, or should I just try adding more freon. Do you need to discharge the system to replace the cycle switch?
95 Explorer
low side: 50psi
high side: 50 psi
outside temp: around 60 degrees F
humdity: around 70%
thanks
aric
95 Explorer
low side: 50psi
high side: 50 psi
humdity: around 70%
thanks
aric
