Confused about write-up | Ford Explorer Forums
jtm087 said:
http://www.ford-trucks.com/forums/showthread.php?t=364301
This write-up says for 97-03 explorers, i have a 96, this wirte-up is the same for them too right?
Where does it say "Explorers"? I see F-150 in the title:
"How to replace the ball joints on your 97-03 F-150 4X4"
Last I checked, the F-150 is a different beast with little crossover with the Ex.
dang your right, well i found this link in one of the ball joint posts after doing a search, well is it the same? this is the only detailed write up i have found and i searched through the forum for hours
Same process, different torques.
The front end on the F-150 is basically just an up-sized version of that on the Explorer/Ranger. Some differences, but very similar in design.
-Joe
thanks for the help! i like to get a detailed enough write-up before i start something, cause the manuals and cd's are way to vague and unless you are an experienced mechanic, they do nothing for you but confuse you with a bunch of words u dont understand
