Control trac part sensor part numbers | Ford Explorer Forums
Suzuki14258
Texas
1995 Explorer xlt awd
Howdy
I’m having issues with my control trac on my 1995 ford explorer. I’m getting the 4x4 flashing six times above 35mph. I took both sensors off and cleaned them. Minor shavings on both but the front behind shift motor had a small crack in it. That did help but didn’t fix it. I suspect the front one is the bad one. I also found an exposed wire on the rear one. I’m going to replace them both but having an issue finding the correct part numbers. Does anyone have the correct part numbers for both sensors or have some they want to sale?
Found em!
Motorcraft SW-5644
And
Motorcraft SW-5645
I found them in this thread;
They are the same sensors in most torque on demand t cases from ford 95-2014 or so
Pricey little buggers. I have thrown so many of these away it’s not even funny. I do have 2-3 of these t cases outside in trucks I can pull some sensors if you get desperate
Found em!
Motorcraft SW-5644
And
Motorcraft SW-5645
I ow you huge! Have two motorcrafts coming from rock auto for 100.00. Thank you so much.
