atistang
- December 17, 2007
- Ohio
- 94 XLT
I just got my explorer legal a few days ago, so at work before i left last night i got under it with it running looking for leaks. I notices it had a steady drip of coolant coming from the fan shroud. So today i removed the fan and shroud and i can't tell if it is the radiator or the side tank seals leaking because coolant is everywhere. So i sprayed everything off with water, then dried it with the air compressor. Then i ran it without the fan (running the heat full blast was enough to keep it from over heating while just idling). after running for almost an hour, it didn't leak a drop. I put the fan back on and let it run for 3 mins and there is a puddle under it.
so i shut it off, take the bolts out of the fan shroud and move it forward, the whole radiator is wet. Apparently it is such a slight leak that without the fan pulling it doesn't leak. It doesn't really make sense but thats all i can figure. so christmas day i get to pull the rad out and pressure test it. Oh what a way to spend christmas day lol
