Coolant Leak | Ford Explorer Forums
Coolant Leak
aussie bruce
Lake Macquarie, Australia
97 XLT
Hello one & all. Hope you can help with a small water leak....and it really is a sneaky bugger. After "professional diagnosis" I replaced radiator, water pump, and all hoses. There are no obvious leaks, no coolant in oil, no oil in coolant, but I am losing about 2 litres every three days. There is no water ponding under the tail pipe, and no water left on the ground. Mates have suggested cracked head or head gasket failure. Does any one have any suggestions?
check the carpet on your passenger side floor...i have had heater cores leak and never even new it until i felt the carpet...i hope thats it cause it is a cheap, quick fix...:D
Thanks for the post tbars4. No water on carpet...guess its not that. Found crack in thermostat housing, and had it replaced. Just waiting to see if coolant loss continues
Thanks BrooklynBay. Pressurised system, and found small crack in thermostat housing. Replaced that and now waiting to see if coolant loss continues
