sroth004
- July 19, 2019
- Harrisburg, PA
- 1994 Ford Explorer XLT
Hello all, having a cooling system issue or issues on my '94 Explorer with 82k miles that I'd like to run past the group. I am the second owner having purchased it a few years ago with a bit over 60k miles from the daughter of the original owner. I sat indoor for a couple of years prior to my purchase. Sorry in advance for the long story.
Last Spring I notice the coolant in both the radiator and overflow tank had turned very dark, almost "greyish" and had a odd consistency. I drained/flushed/refilled/bled the coolant and within a few hundred miles the new coolant started to look the same greyish. Brought the car to a garage that has done quite a bit of work on this vehicle including head gaskets due to external coolant leaking at the rear of both cylinder banks. The shop flushed the system again and also replaced the thermostat and temp gauge sensor with the Motorcraft units I provided (the correct 197 or 198 degree thermostat). After the work was completed the X exhibited wide swings of the temp gauge as it was driven, swinging as far right as just below the line on the hot side of the gauge, with the coolant again becoming greyish fairly quickly. I sent coolant and oil samples to for analysis, with testing indicating no oil in the coolant and no coolant in the oil. The X was stored indoors for the Summer and when I pulled it out to get ready for Winter use attempted to purge the air in the system that was easily felt in the top radiator hose consistent with the swinging of the temp gauge to the hot side. Purging the air helped but did not eliminate the gauge swing so I assumed I was no successful at purging all of the air.
I brought the truck back to the shop that completed the last flush. They flushed the system again, with feedback was that they felt there was stop leak in the system at some point based on there being small black solid debris in the flushed coolant and recommended replacement of the radiator, water pump, etc...I let them replace the radiator, water pump, thermostat, etc...but not the heater core (no way was I removing the dash) along with another full flush. I asked and they did not recommend replacing hoses, which I believe may be original. The swinging of the temp gauge is much improved but not resolved (I have not checked for air in the system yet) however the coolant has again turned dark.
At this point I am stumped and definitely not going back to the same shop. I have not sent samples of this oil and coolant for testing yet and have not removed the valve covers or otherwise looked for cracked heads. Of note, I do not believe the engine has overheated as the gauge swinging never sat toward the right for more than a second or two and is tied to air in the top hose where the temp sensors reside.
Any thoughts or suggestions on potential next steps would be appreciated.
Thanks
Steve R.
Thanks
Steve R.
