white96x
- September 4, 2002
- Rancho Cuc,Ca(home) SLO,Ca(school)
- 1997 E.B.
i'm assuming this is the right forum..here goes: i was having some problem with my rear end lately, i had taken it apart and knew the bearing were shot, so i replaced those, and while i was at it i noticed my ring had a 'hairline' crack along where some teeth were grinded down to put the notch pin back in, so i was doing some mild offroading this weekend and i hear a loud pop in the rear and then the truck was done after...so i had it towed and my local shop said that the ring had cracked and even showed it to me. they said when you do gear swaps you're not supposed to grind down any teeth or you'll weaken the structural integrity of the ring(which made sense) and also since my stock carrier came with a limited slip it was reused in my original gear swap also and the shop said that you are supposed to use a different carrier to accomodate the larger ring and pinion...so i obviously know i need a new ring and pinion but are they scammin me on the new carrier? they quoted me a grand for new bearings, ring, pinion, and carrier with new posi, but i'm wondering if i could just get away with the ring and pinion...your thoughts?
