Vallan
- February 19, 2010
- Tulsa, OK
- 97 Explorer AWD 5.0L
Alternate way
Thanks for the great info! I modified this slightly and had great results.
Accessing the switch
I only needed to replace my on/off cruise switch which for me was located on the left side of my steering wheel. Wiring harness was ok. I did NOT disconnect the battery cable, but did wear safety glasses. Why? Because I never disconnected the air bag. Popped off both plastic plugs, removes both bolts (horn honks when you unscrew, warn the spouse in advance
). I used a bungee cord to lash the air bag module out of the way but didn't disconnect it or pull on the connector hard. My rationale, I'm not removing it or making changes to an electrical connection it uses. USE YOUR OWN BEST JUDGEMENT
Easier Way to Remove Connectors
Forget wiggling the connector hoping your fingers don't slip off and pull the wires out of the connector. There is a small curved area at the bottom of the connector. With a small screwdriver, you can pry it up a bit on one side, then the other. Repeat until the connecter is free from the socket. Takes about 10 secs. See pics.
