bubs67z28
- February 16, 2009
- Surprise,AZ
- 96 4door 5spd XLT
Cruise Inop
Budwich, Thank's for pointing me in the right direction. I felt that since the starter would not engage to crank the engine unless I had the clutch pedal depressed i was all good with the (CPP). Clutch Pedal Position Switch.
Wrong!! It seems as you mentioned it will also deactivate the speed control system (CC) when the clutch pedal is depressed. I did not realize that?
You see the PO had the clutch replaced a month before my purchasing the X.
It seems they forgot to rotate (CPP) and snap in the plastic retainer. Once I got it attached to the clutch master cylinder pushrod properly, I went for a drive. Lo and behold it works like a champ!!!
I just need to replace the bulb in on/off CC switch.
Thank you to all those who replied!! Especially you Budwich!!!
Cheers! Rick
If I understand you correctly, you mean that the switch tested OK... basically it has continuity.... I kind of figured that cause your dash light comes on. Although it is probably a good idea to replace the switch (I haven't yet... me dummy plus cash squeezed), your problem is probably in your control module / linkage to the throttle system.... or possibly your clutch position switch. One small question... does your light go out and act "normally" when you clutch or depress your brake when you are going down the road with cc "on" and "activated" according to its "thinking"????
As for others, if your light doesn't come on or only comes on briefly, it is likely you have switch problems, beit, the pressure switch, the BOO, the clutch position, or the activation switch/wiring in the steering. IF your light comes on and stays on BUT reacts normally to brake depresses, clutching etc, then it is likely you have a linkage issue between the cc servo and the throttle system.
Cheers! Rick
