Cruise control won't work. | Ford Explorer Forums
Dj1026
Ohio
1998 explorer
Hello I recently had an engine put in my 98 ford explorer everything works great but the cruise control won't work. At first when I turned it on the cruise control light turned on then off immediately. Now it's not even doing that. It worked when the previous engine was in. It's the 4.0 v6 ohc any suggestions? Thanks!
Does the horn work?
If not, check the yellow fuse under the hood.
If the fuse is ok, either something is unhooked under the hood, or the clockspring is bad in the steering wheel. Is the brake switch plugged in on the master cylinder? Possibility the switch is bad after the swap.
