rocket22
- August 28, 2007
- La Grange, IL
- 2002 Explorer xlt 4 wd
Over the past 6 months I have had the CEL light on and the codes from a 1995 (OBDI) are indicating EGR. (I dont recall the code number) I replaced the EGR and the problem continued: Rough idle, surging at low idle, and kinda sluggish. I removed the vacuum line from the top of the EGR valve (Leading the the EGR Solinoid) and plugged it and the engine ran fine, great idle, no issues with performance. I figured it was the EGR Control Solinoid (connected to the plastic intake) which I changed and connected everything up. It ran rough as before so I removed the new EGR Control and reinstalled the old one. (I didnt have a testing method for it). I have also changed plugs, wires, air filter, cahnged vacuum lines, and tested the IAC.
Two questions: What could the problem be? I will pull the codes later.
Is there any issue with running it like this? Bottom line is the EGR wont open and some of the gas wont recirculate so I wont pass emissions, which isnt required by a pre 1996 in Illinois. I use this for towing and local stuff, so i am perfectly fine driving like this
(Note: please no replies about destroying the ozone, the truck still has a cat and I am sure my lawnmower kicks out more pollutants.)
