custom 2 inch suspension lift questions | Ford Explorer Forums
tealtterror
Murfreesboro, North Carolina
'94 XLT
if i throw a 2" coil spacer under the front and a 2" in the rear..... will i be able to do this without extending my breaklines and maybe run the same shocks for just a little while. let me know something
This is commonly done. Though you will have to do the rear with either shackles or AAL's cause there isnt any coils back there to space. Your Camber will be WAYYY off though. WIll desperately need an alignment and verry likely need new camber bushings.
Im still running the same shocks with that setup and its fine.
