TTG
- April 14, 2005
- Florida Gulf Coast University, Fort Myers, Florida
- '95 Sport
Well, as I'm getting closer and closer to having the funds for my system, I'm looking more into the construction of said stealth box. As such I've got some questions.
1) Is it as easy to put a 12 inch sub in there as a 10 inch one? The BA G2 series comes in both versions, and for another 20 bucks I see on reason to not go up to 12 inches.
2) How Big is the factory amp? I was planning on bypassing it, and replacing the amp with the one for my sub. However, most amps I've seen are rather large, and I'd need either 1 cu.ft. or 0.5 cu.ft. for the 12 and 10 inch subs respectively for my box. A little worried I might run out of room.
3) Will surrounding the box with Dynamat help any? Or would that hurt it?
4) How do you attack the stealth box? If its just sitting there it would vibrate a lot causing bad rattling. I figured mounting it to the interior panel would be the best idea, so I didn't have screw or whatever in my body.
5) Is there such thing as HDF? Higher density than MDF? If so. is it better to use than MDF for making a box?
Any insight would be appreciated.
