SBJ420
- June 12, 2006
- Windsor NS
- 95 XLT
So I started my D35 swap today, got the D28 all out today, tomorrow put the D35 in. Only thing I need to do before I put it in is get the springs out. Might need to take it to a shop to get them off. Here is what I got down so far..... This is not sitting on those tires at all. Those are there to make me feel a little better about getting under this thing! its on 6ton jack stands
10am I losened as much as I could before I put it on jack stands so I was not prying on anything too hard when I was under the truck. If any one has any hints on getting those springs off the axles it would be great!
First thing I did was take the drive shaft off
Than I took the bolts off of the steering stablalizer and pitman arm.
Than break lines and socks
Than the springs and beams
Now this is where I am left at for the day. 5pm
The radius arms are 28mm, also where the springs bolt to the radius arms is 28mm
One beam was 15mm and 18mm. Other was 18mm
