iowa_hick
- May 7, 2019
- Iowa
- 2002 Ford Explorer EB
Recently I was having an issue with the transmission in my 2002 Eddie Bauer with the 4.6l engine. Based on research on this board and a few other places, I concluded it was the servo pins, which I replaced with the version with o-rings. This must have been the issue, because the transmission worked flawlessly when I was done and I drove it around 50 miles afterwards with no issues.
Unfortunately, it appears that when I reinstalled the snap ring for the servo pin, I must have damaged the lip on the transmission case that retains it, because this morning when I moved the Explorer the snap ring and a section of that lip popped off, followed by the majority of my transmission fluid.
Does anyone know if there's any way to repair the case in a situation like this? If it comes down to replacing the transmission, I'll probably just have to scrap the truck out because it's not worth the cost.
Thanks for any help you can provide!
Jake
Jake
