dana 44 help | Ford Explorer - Ford Ranger Forums - Serious Explorations
dana 44 help
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Typically, if the camber is off, then there's a bent component, or the inner knuckle wasn't aligned properly before welding.
But none the less, there are eccentric upper ball joint sleeves:
cole01
Dryden
1986 Bronco 2
thanks for the help i guess its going to the shop to be alined
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Well Im not sure the shop can't do anything about camber unless they install those eccentric upper ball joint sleeves.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
Make sure the toe and caster are set right before you think about the camber. Sometimes a bad toe/caster setting will make a solid axle appear to have bad camber when it really doesnt.
Other than that, about all you can do with it is the offset balljoint sleeves as mentioned above.
