locomarine
- September 14, 2016
- SF Bay, CA
- 2016 Explorer Sport
I recently installed a dash cam hardwired to the fuse box (under dash) in my 2016 Explorer Sport using a fuse tap that came with the hardwire kit. The kit has a voltage cut-off box which is set for 11.6v. I have it tapped to an always hot fuse so the camera will work when the car is off. Works as designed as the camera stays on when the car is off. The issue I'm having is whenever I start the car, the camera power cycles off. I'm guessing when the car is started, power is ever so briefly cut from the fuse panel causing the hardwire controller to shut down?
Does anyone know if the power is ever so briefly interrupted upon ignition? I haven't had a chance to test with a multimeter and have someone else start the car since I won't be able to reach up and start myself, but this will bug me all day so thought I would post.
