Deminsions on Roadbully Lift Kit | Ford Explorer Forums
Don't make anything over 2.5"...
Thanks for the advise. Can you get me the "deminsions" for actual spacers?
Rather than make your own just pick up a set from Brandon @ BTF fab. here on the forum. To me, for $250 shipped it's worth skipping the headache making your own. Plus it supports the forum and its vendors.
The reason you should not make spacers over 2.5 inches is because it will wear out your suspension components much faster, especially your ball joints. I have seen pictures where the ball joints have ripped out of the control arm from 3 inch spacers. Also, I believe there were issues with the cv axle angle.
If you want to be that much higher, do the 2.5 spacer with a 1.5 body lift
