Hi all, I've been trying to use this ex as a learning experience for myself, as well as to eventually use as my daily driver. Obviously, for that to be the case, it needs to be running perfectly, and i shouldn't have to worry about it being a danger to myself or others. However, with this particular issue, I'm stumped.
The ole' rough idle. Ah yes, the very bane of my existence. Starts up rough when warm, idles rough no matter what i do, and (sometimes) will stall at stoplights, or long periods of idle.
What have I done to fix it? Well, i've replaced the positive battery cable, checked for vacuum leaks, cleaned the maf, replaced the ects, replaced sparkplugs and wires, cleaned the throttle body, checked the large intake tube (plastic) for cracks, checked each vacuum line on the tree for leaks (done by plugging them simultaneously, this provided no change to the idle), and checked the iac (I unplugged it, and the engine slowly died).
At this point, the only things I HAVEN'T done, are replacing the MAF, replacing the pcv valve, replacing IAC (though it seems to be working fine), or anything relating to fuel.
Fortunately, it's annoyed me enough at this point to document it, so here's a video of a (warm) start.
Note, the oil guage ALWAYS reads high, and always "flickers" like that. When the idle is getting rough, the voltage meter also does this (because its about to stall).
Main points to take away here are the surging and rough idle. If anyone else notices anything that is ALSO an issue, or has any questions, please let me know.
Thanks in advance, and have a
yeahhhhhhhh. It's pretty gunked up, and definitely needs to be flushed. How can i really tell if oil is mixed in though? I've smelled it, and while it doesnt smell great (at all) it doesnt really smell like oil. But i could be wrong :/
Just replaced my IAC. It was idling like crap. Sometimes it would hesitate and take a couple of key turns to start. The RPMs would drop like crazy at a red light especially if the AC was on. I believe an explorer reads 60% as %100 open. Not that it matters. Here’s the deal. If the IAC gets gummed it hesitates. When the AC kicks on and it screams more air needed a message is sent to the IAC and a solenoid fires to open or close it. If it hesitates or drags it either won’t open enough and you get your rough idle or it tries to stall. An IAC is like $30. Replace it.
