differential fluid change | Ford Explorer Forums
cdrive
Milwaukee WI
1999 Explorer Sport
howdy all
I've got a 99 Sport and I think it's probably time time to do the differential fluid. Do I need friction modifier in the rear? Recommendations on fluid are welcome; I was thinking Mobil 1 synthetic, but I'll entertain other fluids as well.
Thanx in advance
whats the axle code?
Its a code found on the driver's door sticker; it designates what rear end you have. Get the code and post it here, we will help you.
As for the friction modifier, I have never used any in my LS 3.73; and never an issue with it either.
I use Amsoil in mine and have used Mobil 1 in the past.
Good luck ...
sorry, i meant what is the axle code for that particular vehicle, good definition though :)
it's an axle code 42
I'm just looking to change the fluid as I figure it's well past due, and I am gunning for Aldive's 30 mpg :P
Aldive, what weight Amsoil are you using?
i believe that is a non limited slip 4.10 axle. How much of a difference will fresh diff fluid make in fuel economy?
Its not whether its fresh, the key is whether its synthetic ( for better mileage ).
Aldive, did you notice a difference between the Mobil 1 and the Amsoil?
