ErickSaint
- September 23, 2006
- Milwaukee, WI
- '94 XLT
Recently we have had a real cold snap it is -9 today with a -25 wind chill. I have noticed that there is a strange problem recently. When the engine is still cold it seems to be slipping. From a stop I step on the gas and it will sometimes rev to about 1500 then slam into gear. Other times it works fine. The other thing I have noticed is that from a stop I give it gas and it never seems to get above 1000 pretty much just sits right on the line. If I goose the gas sometimes it will thump into gear other times it will not, just stays at the same rpm. All problems will go away after I have done enough driving to get everything warmed up a bit.
Today as cold as it it I went to check the trans fluid and the whole fill tube came out of the tranny. I tried looking through old posts to see where it hooks back up but haven't really found any pics of that side of the case. I'm only trying to find a pic cuz it's damn cold and I have no garage to work in. If it's something I need a jack to do I have to do it on the cold road in front of my house.
Could the tube being loose cause a loss of fluid which may be my problem?
Forgot to add, 94 4.0 A4LD
