Robert
- October 26, 1999
- Location
- CA
- Kelseyville, CA
- '13 Ram 1500 Longhorn
The axle is always engaged on all 4WDs that use CV joints as opposed to hubs at all times. On '97 and up Explorers though the driveshaft is also always engaged (I'm sure this is what you meant though
) unless it has been modified to force it into real 2WD such as mine has.
Since the NoSlip only locks when it is getting power through the driveshaft and I can eliminate 100% of the power going to my front driveshaft it is no different than having a 2WD truck until I put it into 4WD. My only concerns though were that I would loose my Auto mode for all practical purposes. I certainly wouldn't want to enable my Auto mode on the streets when traction was marginal. When my rear tires did slip, both front tires would then start pulling which would then reveal the downsides to having a front locker. My conern was if I was rounding a turn in the rain and happened to give it a bit too much gas. I didn't want it pulling me into the next lane as the fronts started to pull. The only way I could prevent that would be to keep it in 2WD mode.
It became a tradeoff no more Auto mode with the benefit of having front and rear lockers for hard-core 4 wheeling or leave my front open and just put a locker in the rear which allows me to keep using my Auto mode in the rain. I decided to keep my Auto mode and decided against putting the NoSlip in the front. I'm only putting it in the rear. I like the idea of a selectable locker though for the front and will look into this in more detail. This would let me keep my Auto for the street and have front and rear lockers for when it gets really bad.
