Bronco89
- May 12, 2012
- Cleveland Ohio
- 98 Explorer
Ok so I just read in a post somewhere that if you step up the rear gears, you have to also change out the fronts for the TC to last, is this true?
Im going to put in 4.56 gears in the back to compensate for going to 33s. The gears in the rear now are 4.10s, do i also have to change the fronts and to what ratio then. In the reading from searches i have done, nobody mentioned having to do the fronts also, just looking for a straight answer. Thanks.
