Do I need Caster/Camber bushing with.... | Ford Explorer Forums
nomad
Denver, Colorado
'92 Navajo
Do I need Caster/Camber bushing with 1.5-2" SJ lift??
I am ready to get my 1.5-2" Skyjacler lift and the guy at 4 wheel part tells me I will need Caster/Camber bushings to be able to align it. I knew I would need an alignment but did not know I would need new bushings. Does this sound correct? I have a 92 Navajo, I am planning on adding the new coils from the Skyjacker lift kit and lifting the rear with shackles. Will this be an even lift? Also do I need to take it to a 4 wheel place to get aligned or can I do that where ever I buy my new BFG A/t's at? Thanks in Advance for any help!!!!
Any place should be able to align it, but I recomend taking it to a shop that specializes in undercar work. I wouldn't trust any mass tire distributor (Sears, Big-O, Discount Tire, Sam's Club, etc...) to do the alignment. More than likely all they will do is set the toe and tell you that there is no way they could adjust anything else. As far as the caster/camber bushings go, I didn't need to replace mine when I put the F-150 spacers in, but that doesn't mean that your's wont. That's another reason I recomend taking it to a specialtyshop. If they need the bushings you can purchase them as part of the alignment.
