Dodge 20"s on a Gen 1? | Ford Explorer Forums
x9293
Independence, Mo
98 xlt
I know where i can get a set of dodge 20's pretty cheap and am cosidering putting them on my X. I figure i will just have to get the lug adapters from 5x4.5 to 5x5.5 and maybe a body lift. What do you guys think? Do you think it will look good? Do you think i will have any problems in the long run?
20's with wheel adapters will stick out pretty far, and a body lift would make it look even worse IMO
Doesnt the first gen haev hubs in front too? The wheels prob wont fit if you have a 4x4...
Good point...most street wheels are mant for 2wd's...You would have to get them machined...Not worth it...
The Dodge wheels have quite a bit of offset, so the adapters would put them just about where they should be. Have to check the hub section to see if the Ford Hub would fit. It just might. The tire height will determine if you need a lift or not.
u will probably be ok if you go with a 30 or 40 series tire.
