Possible cause could be a broken wire in the boot between the body and the driver's door. Others have had luck spraying WD-40 into the door at the hinges. There are a bunch of threads on here concerning the door-ajar problem. I recommend searching that first to get the low-down on using WD-40. If that fails then:
