Door Ajar Issue
FordFan45662
KY
2003 Ford Explorer XLT
Ok just picked up a 2003 Explorer XLT 4.6 4x4. The door ajar light was on the dash. I sprayed lube in every door latch, and opened and closed the doors several times. That didnt work. I went to Google and found that they have problems with broken wires in the driver door boot. I found 3 broken wires (2 for passenger window and a purple black wire). I fixed those wires. I noticed that when I shut the truck off the radio stays on until I open the door. You would think if it thinks a door is "open" it would shut off when I shut the engine off. I am stumped and dont know what else to look at. I have looked at the wires in the driver kick panel and didnt see an issue there. Any help would be greatly appreciated. Thanks in advance.
Rayan
2002 Ford Explorer XLT
So, the Door Ajar Light is still on after you fixed the wires?
FordFan45662
KY
Yes sir it is .I'm good with car electronics but this has me stumped
scarletgem
Bloomington, In
'2003 EB 4.0 AT 4x4
that is normal for ford radios to stay on until door is opened..in my experience...enjoy the tunes.
FordFan45662
KY
Where can I find the door ajar module?
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
2003 Ford Explorer Owners Manual (Page 53)
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/03expog5e.pdf
Accessory delay
With accessory delay, the window switches and audio system may be used for up to ten minutes after the ignition switch is turned to the OFF position or until any door is opened.
Rayan
That is strange. I know the radio and power windows will work until you open the door like @swshawaii said, but the door ajar light should have turned off when the key is turned and the doors are closed. The car responding to you opening the door and the radio turning off leads me to think that your door ajar sensor is not at fault, but I'm no expert. When my door ajar light stayed on I replaced it with a sensor from a junkyard car, and a year later I have not had any issues with it.
FordFan45662
KY
I am going to try a new sensor in the driver door tomorrow. Ive asked a ford mechanic and they are stumped too.
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
If the radio turns off with the opening of the drivers door, I’d be led to believe that the “door ajar” is coming from another door.
Open each door and see if one of them doesn’t kill the radio. Not sure if the hatch kills the radio.
FordFan45662
KY
both rear doors didnt shut the radio off when i tried it today so I am going to check them next
vipersinu2
The Big City of Orange City, Florida
2019 Navigator 450hp
if you ever have a problem with you explorer check out the Ford tech, he probably has a video on it!
FordFan45662
KY
I'm still stumped. Don't know what to check next
rasouth
Riverside, CA
96 Explorer XLT 4.0 OHV
I had the same "Door Ajar" problem with my '96. I dropped by the local Ford dealer and a technician said spray WD40 in and around mechanism, especially where sensors are to clean the connections. She said it might take a few tries. Mine happened to be rear glass latch. If you have access to an air tank and a long air nozzle you might be able to blow it clean.
scarletgem
Bloomington, In
'2003 EB 4.0 AT 4x4
I will second this fix...as it worked for me. You may want to open and close doors a bunch to loosen it the sensors. Drivers key pad started working correctly again. Amazing how the car thinks your door is open.
Just a note my explorer was an estate buy and was sitting a little while before I bought it. I think that was the contributor to this issue.
B crazy door lock/door ajar issue Stock 2002 - 2005 Explorers 2
L Door Ajar issue "fixed" Stock 2002 - 2005 Explorers 4
D Door ajar issue Stock 2002 - 2005 Explorers 0
D Door Ajar / Dimmer Switch Issue Stock 2002 - 2005 Explorers 8
D Door ajar, rear window problems, possible electrical issue Stock 2002 - 2005 Explorers 1
S New to me 2005 Explorer - Visor wiring harness and door ajar issue related? Stock 2002 - 2005 Explorers 3
K Door Ajar Issue Stock 2002 - 2005 Explorers 3
C Weird door ajar issue Stock 2002 - 2005 Explorers 5
M How to find/fix door open switches (door ajar issue)? Stock 2002 - 2005 Explorers 11
J Power Door Lock/Remote/Door Ajar Light Issue Stock 2002 - 2005 Explorers 27
L '03 Expo Electrical Issue! Door Ajar but doors are shut.. Stock 2002 - 2005 Explorers 3
G 2002 Explorer alarm issue /door ajar Stock 2002 - 2005 Explorers 21
M Door ajar issue on a 2002 Ford Explorer. Stock 2002 - 2005 Explorers 3
B Help with a door ajar issue Stock 2002 - 2005 Explorers 7
H Door ajar issue on my 2002 Explorer. Stock 2002 - 2005 Explorers 4
F Driver Door Electrical Problems, Door Ajar Light Stock 2002 - 2005 Explorers 4
N Dome light stays on BUT no door ajar Stock 2002 - 2005 Explorers 3
J Door ajar idiot light won't turn off despite all doors being securely closed Stock 2002 - 2005 Explorers 10
M door ajar issues Stock 2002 - 2005 Explorers 2
M Lessons learned, electrical issues (door ajar, power windows, out side rear view mirrors, power locks) Stock 2002 - 2005 Explorers 2
B 02 Explorer: Passenger side door ajar switch work on drivers side Stock 2002 - 2005 Explorers 3
W Door ajar Stock 2002 - 2005 Explorers 0
E What triggers "Door ajar" light ? Stock 2002 - 2005 Explorers 4
V Opposite door ajar problem Stock 2002 - 2005 Explorers 1
F Door ajar Stock 2002 - 2005 Explorers 4
M No Start or Crank, also random door ajar and info center reset Stock 2002 - 2005 Explorers 2
R Autolamp, door ajar, senile HVAC, no unlock Stock 2002 - 2005 Explorers 1
J Door ajar light on Stock 2002 - 2005 Explorers 6
T Door Ajar Warning Won't Go Away Stock 2002 - 2005 Explorers 11
I 02 Door ajar buzzer. Stock 2002 - 2005 Explorers 2
R 2002 "DOOR AJAR" which door, how do I narrow it down? Stock 2002 - 2005 Explorers 8
M Infamous Door Ajar Stock 2002 - 2005 Explorers 12
W Security alarm, auto unlock, parking lights, door ajar, oh my! Stock 2002 - 2005 Explorers 15
J Does the A/C work when the door ajar light is lit? Stock 2002 - 2005 Explorers 20
F Door Ajar Stock 2002 - 2005 Explorers 4
S Door ajar Stock 2002 - 2005 Explorers 7
E Door ajar switch fix Stock 2002 - 2005 Explorers 1
J Door ajar problem Stock 2002 - 2005 Explorers 11
M Door ajar light stays on and alarm won't go off... Stock 2002 - 2005 Explorers 8
F door ajar buzzer and horn Stock 2002 - 2005 Explorers 4
R Door Ajar Alarm Stock 2002 - 2005 Explorers 1
S Door ajar switch replacmeants. Stock 2002 - 2005 Explorers 1
R Door ajar switch removal? Stock 2002 - 2005 Explorers 2
F Door Ajar light on dash fixed finally after 1 year Stock 2002 - 2005 Explorers 1
F Door Ajar light problem in the winter or when it rains? Stock 2002 - 2005 Explorers 2
D Odd electrical gremlin > Drivers headlight out + door ajar Stock 2002 - 2005 Explorers 1
X Ever change door ajar switch? Stock 2002 - 2005 Explorers 0
F ABS light on and Door Ajar Light on Stock 2002 - 2005 Explorers 2
trucku Door Ajar alert when defrost button pushed FIXED!! Stock 2002 - 2005 Explorers 3
M door ajar light and chime Stock 2002 - 2005 Explorers 0
Similar threads
