door ajar light help | Ford Explorer Forums
tjrap77
my door ajar light is almays on when vehicle is running
I checked all doors and hatch, replaced switch under the hood (thought it was faulty)
anyone have voltage readings I can take at other switches?
any other help will be appreciated
tjrap77
For very many cases the issue is that the switches in the doors and latches which indicate that the door is open get stuck. A light spray of WD-40 often fixes the issue. Here is a thread on this, there are many others like it:
http://explorerforum.com/forums/showthread.php?t=154611
WD-40 fixed this issue in my Explorer - I sprayed it in all 4 door latches and on the two rear latches.
Sometimes this will not fix the issue. The next most common reason is that the wires in the door are broken - a more involved fix than the WD-40. The lazy person would start with the WD-40 before trying to find broken wires.
Rumple
I've had the exact same issue since last November. I've done the WD-40 trick with no luck. I assumed it was the rear hatch that was giving the door ajar signal because my rear wiper stopped working simultaneously, but I have no clue how to check the wiring back there or anywhere else.
This problem is seriously driving me nuts.
Hey everyone im new to the forums. I do know wats wrong with your door ajar light. if your like me, and cant use the lock and unlock either or the window tilt switch, i think it has something to do with the wires in the harness. Maybe one is cut, or the ground wire is messed up because it happened to me and when i pushed on the harness, it would work. Just a thought....
This morning I think I narrowed down the problem to my rear hatch because it is the only door that doesn't trigger the dome lights to come on. Any advice?
