Door ajar light stays on and alarm won't go off...
MintyFresh
2002 XLT Explorer
door ajar light stuck on along with interior lights.
Thoughts?
MintyFresh
2002 XLT Explorer
Did that, no luck.
Edit: the door alarm doesn't go off on the front left door so I pin pointed it to that door.
Took door latch off and everything looks ok. Maybe the electrical inside the door latch is bad?
TechGuru
Location
Texas
2003 XLS 4X4 4.0L FLEX
LMHmedchem
2002 Explorer XLT v8
This can also be a broken wire in in the door boot. I can't say which is more trouble to check. I guess the boot can be checked and ruled out without buying any replacement parts.
Here is a great thread by synyster for checking for broken wires, link courtesy of BigRondo,
http://www.explorerforum.com/forums/showthread.php?t=270081
and for removing the door panel, from the same source,
http://www.explorerforum.com/forums/showthread.php?t=303524
If it does end up being the switch, this is a thread from borland, also courtesy of BigRondo.
http://www.explorerforum.com/forums/showthread.php?t=249253
You do have to use allot of WD40 on the door latches, so if you only used a little, it is worth trying again.
LMHmedchem
TechGuru
Location
Texas
LMHmedchem
+10 :thumbsup:
Spray like you're trying to wash it, not oil it, then open/close the door many times.
MintyFresh
2002 XLT Explorer
Thanks guys, I sprayed 2 different kinds of lubes over the past 3 days and still doesn't work. Just going to buy a new switch and hopefully that does the trick!
