door locks question | Ford Explorer Forums
door locks question
cowboyearl
columbia kentucky
2015 exployer limited
After driving and coming to a stop, ignition off, my rear doors don't unlock. This is with a passanger in the the back seat. I am not outside the vehicle.The child door lock is in the correct position. What settings do i use to get the rear doors to unlock?
Thanks,
Earl
After driving and coming to a stop, ignition off, my rear doors don't unlock. The child door lock is in the correct position. What settings do i use to get the rear doors to unlock?
Thanks,
Earl
I see you have a 2012 Exployer. New model??:D
Is this a change from what it did before? When the vehicle is locked and you grab the driver's door handle do all 4 doors unlock? That is how I set mine up.
All doors unlock, not just the driver's door.
Hi Peter
How is it that you set your door up tondo this. Right now when I reach for the handle the driver door is the only one that opens
Thanks in advance
-v.
This is in your vehicle set-up with the left side LCD screen. You can select for the driver's door to unlock, or all 4 doors.
Hi Peter
Thanks in advance
-v.
Hi V. The procedure is covered in the Owner's Guide in the Locks and Security section under Power door lock switch autounlock enable/disable procedure. I'm quite sure that is what I used. I set it up over a year ago.
I did not do it via the left screen settings. I think those setting are for the lock/unlock feature when you begin to drive/stop.
