There is a bolt that goes down through that harness. You use a 10mm socket to remove it.. You access the bolt by popping off a little black plug on the top of the harness. Then, to remove the harness that is left sticking out the door, you have to pull back the carpet, take off the kick panel, and pull off the lower part of the dash. You should be able to reach all the plugs then.
