koda2000
- September 2, 2011
- x
It must be something in the air, but I suddenly find my door striker bushings are breaking. This causes rattling and a loud clicking noise when opening the doors. This has started happening on 3 of our Explorers/Mountaineers. Based on a thread by drdoom, I made and installed new door and ST tailgate striker bushings out of 1/2 PEX. For $1.86 I have enough material to make about 60 new bushings. I believe the PEX will be more durable than the OE bushing material. I wish the PEX came in black or grey, but you do have the choice of red, blue or white to select from. I went with the blue. I found the PEX needs to be reduced in diameter a bit to work properly for the doors, but it will work w/out modification for the ST's tailgate. For the doors I installed the PEX on the OE striker bolt and chucked it in my cordless drill. Then I spun the bolt while using a rasp to take down the diameter to the proper size, finishing the surface off with a fine file.
Note: The 1/2" PEX will not work for the bushings on the regular Explore's lift-gate, because the bolts/bushings are larger in diameter.
