dreaded po741 trans converter lockup code SOLVED!
02ex4x4
last night my od light started flashing around 50mph . I shut it off to reset it and it stayed off the rest of the drive home about 30min at about 50mph was good all morning . now its at it again. some background it was a used trans I installed looked to have a newer converter( blue in color) It had some shifting issues so I put a solenoid pack in it from what it seemed like reparable vender and I also installed a transgo shift kit in the valve body. it seemed to help everything in general. that was roughly 8 months ago drive it almost daily never any codes ever for that matter with this trans. so I guess what I'm asking where do I start? do I check pressures? what should I be looking at? did the converter fail or is it in the valve body or just weak pressures? I'm not pulling out bad converter or solenoid pack as I don't have faith in any part newer or not. I do have a hunch that the pump is tired on this trans it does make some noise at wot or harder acceleration. I plan on selling this truck like I was gonna put a for sale sign in it at the end of the month anyway, but I don't want to give it away if I can fix it as I feel it is still a reliable form of transportation. anybody any thought to narrow it down I don't wanna throw parts at it I have pressure gauges and have the means of the pulling the trans and a older brick snap on scanner. any input is welcome
Gilligan
Colorado Springs
2004 Ford Explorer Sport
Need more information.
Engine type. Miles. Year. Age of transmission fluid and filter??
Simple Problems That Trigger the P0741 Code
  1. Defective Engine Coolant Temperature Sending Sensor
    1. Make sure your thermostat and temperature sending unit are good. These are different from the unit that sends a signal to the display in the dash. So your dash can show a good temp when that is not the case. You will need to pull the intake to replace sending unit. You'll need intake seals, thermostat, thermostat seal, and the sensor. When engines sense that their temperatures are too low they can go into limp mode which can cause all sorts of weird issues.
  2. Dirty transmission fluid that restricts the hydraulic passages
    1. Do or get a full fluid flush and filter change. Use Valvoline Transmission Fluid for Older Engines And add LubeGuard to the fluid. One ounce for every quart of transmission fluid in the the system. This has fixed several transmission issues for my family.
Do these first before digging any deeper. Reset your codes. And see how everything behaves. Hate to spend more money fixing expensive things when you don't need to. Shops blink $green$ when you do that!
Good Luck
Gill
02ex4x4
to answer your question I found a burr that was restricting the tcc valve from moving in the valve body, I replaced it with another upgraded sonnex valve making sure to keep it clean. Now everything works as it should.
M Dreaded Transmission Questions... Stock 2002 - 2005 Explorers 3
M 02 Eddie Bauer dreaded transmission question Stock 2002 - 2005 Explorers 3
2 Dreaded trans issues Stock 2002 - 2005 Explorers 18
R Dreaded stuck doors need help! Stock 2002 - 2005 Explorers 1
R The dreaded 5R55S (I think) Stock 2002 - 2005 Explorers 1
R Dreaded timing chain tensioner failure Stock 2002 - 2005 Explorers 4
M Dreaded intermittent gage cluster off and on Stock 2002 - 2005 Explorers 4
J The dreaded spark plug blow out problem Stock 2002 - 2005 Explorers 4
F Dreaded P1309 Stock 2002 - 2005 Explorers 17
L The dreaded broken crossmember bolts.... Stock 2002 - 2005 Explorers 10
C The dreaded Power Door Lock issue Stock 2002 - 2005 Explorers 5
D The dreaded "wrench" light Stock 2002 - 2005 Explorers 1
J The dreaded transmission topic Stock 2002 - 2005 Explorers 11
B 02explorer dreaded 4X4 control module Stock 2002 - 2005 Explorers 3
A the dreaded 'Failsafe mode' Stock 2002 - 2005 Explorers 25
K The Dreaded Whine from the Rear Axle Stock 2002 - 2005 Explorers 2
S Repair Advice on the dreaded timimg chains. Stock 2002 - 2005 Explorers 4
P 2003 Ford Explorer auto trans Stock 2002 - 2005 Explorers 2
M 2002 Explorer 5R55W Trans Won't Go Into Any Gear, No Codes Stock 2002 - 2005 Explorers 1
L air/foam trans fluid Stock 2002 - 2005 Explorers 3
L trans service Stock 2002 - 2005 Explorers 8
Stvincnt installing Rebuilt Trans fo 04 XLS labor time ? Stock 2002 - 2005 Explorers 1
H Can someone tell me what model trans I have Stock 2002 - 2005 Explorers 13
0 looking for the trans solenoid pack wire pinout diagram Stock 2002 - 2005 Explorers 7
F Trans help needed. Stock 2002 - 2005 Explorers 1
H Manual trans swap from a Ranger donor ? Stock 2002 - 2005 Explorers 7
Number4 Thoughts on this trans Stock 2002 - 2005 Explorers 7
H '03 Trans Service Stock 2002 - 2005 Explorers 0
C 03 2x4 to 4x4 trans swap Stock 2002 - 2005 Explorers 3
M 03 Trans issue Stock 2002 - 2005 Explorers 12
M 03 trans problem Stock 2002 - 2005 Explorers 7
M Engine, Trans, or Scrap Stock 2002 - 2005 Explorers 9
P 03 explorer 4.6 how do I I'd trans Stock 2002 - 2005 Explorers 1
T 2004 XLT Eddie Bauer Trans No Go Stock 2002 - 2005 Explorers 12
J 2002 Trans 5R55S checking fill tube fluid keep coming and coming Stock 2002 - 2005 Explorers 1
F Secondary/Auxiliary Trans Filter Stock 2002 - 2005 Explorers 1
0 02 Limited 4.6l 4x4 Trans - Pls Help Stock 2002 - 2005 Explorers 6
R 04 explorer wont shift in to 3rd gear or reverse. Do we have to rebuild trans? Stock 2002 - 2005 Explorers 0
M On the 4.6 is it possible to replace the cats as a unit without dropping the trans crossmember? Stock 2002 - 2005 Explorers 3
C 2003 Explorer Trans Noise & Leak Stock 2002 - 2005 Explorers 0
F Flush and inline filter question for 5R55S trans Stock 2002 - 2005 Explorers 1
0 Hello Another 5R55W conundrum. Any trans gurus? Stock 2002 - 2005 Explorers 17
N Help with trans Stock 2002 - 2005 Explorers 17
C another trans problem Stock 2002 - 2005 Explorers 18
M Grenaded Trans - 02 XLT Stock 2002 - 2005 Explorers 1
J Trans issues Stock 2002 - 2005 Explorers 1
S Engine problem or trans? Im lost Stock 2002 - 2005 Explorers 7
B Aviator slipping from a stop. trans or transfer case? Stock 2002 - 2005 Explorers 7
M Trans trouble Stock 2002 - 2005 Explorers 1
M 5r55w trans Stock 2002 - 2005 Explorers 0
Similar threads
