dreamr
- October 5, 2003
- Lynnwood WA
- 99 XL / 4x4 / 4.0 ohv
Trust me to ask a newbie question, but the search feature borrowed too much of my time telling me the things I was already aware of.....again and again and again.
The story
I nioticed a few months back that the Explorer was running a bit rough for the first minute or so after start up. Ran fine the rest of the time, so I figured it was time for a tune up and she probably was mad at me for parking her outside in the cold.
In early Jan. I proeceeded with abit of maintenance.
Diffs flushed
engine flushed (new filter and amsoil)
replaced coolant
replaced PCV
replaced Spark plugs
replaced plug wires
cleaned K&N (cleaned MAF 2 weeks later just in case it got too oily)
replaced fuel fiflter
and uhh well I probably missed something
In general the condition described above remained the same though my vehicle ran noticeably smoother once warm and fuel consumption dropped slightly.
Today was as any other in the morning. Rough start up, but ran great after a couple seconds. I went too lunch and it started up rough, but was a bit more consistent than a normal morning. It did not go away, and when I drove it, it was obviously missing on at least one cylinder if not randomly. I somehow fought it home though it was bucking and actually had a minor backfire or two.
Once home I checked for codes.....None and no lights either. I checked over all of my work from January.....note around 2500 miles have passed. I found nothing. I pulled out a spare set of plugs and tossed them in. The problem persisted.
The plugs I pulled out looked normal except for the front driver #6? was black and very fouled. The passenger rear (#1 or #3) was redish brown and appeared almost glazed.
All of the secondary resistances on the coil pack were equal and within spec. The primary is difficult to check in the truck, but appeared normal though I couldn't be sure that I had tested at all 3 negative prongs.
I ran a test cycle by disconnecting 1 wire at the coil pack then starting it. The truck ran really bad with every plug wire disconnected (seperately of course) except for # 6. With 6 disconnected it ran like previously.
I had to come in to feed my kid and get her to bed so I can't follow up with the obvious test of borrowing a wire from the mustang to replace #6 till later.
I will post back then, but in the meantime what have I overlooked in my diagnostics???
The story
Diffs flushed
replaced coolant
replaced PCV
replaced plug wires
