2ndcovenant
- March 20, 2015
- 2002ExplXLT 4x4 4.0L 6cyl
Hey folks,
A couple of months ago I had an issue with a Walmart tire and lube in which they pulled my truck backwards while the driver door was open and it hit a pole, and the door itself was moved forward. In other words, the door hinges became misaligned.
I followed the instructions that I found on a website showing how to put a socket into the hinge that needed realigning and slowly closing the door. It did work. I worked fine for a couple of months now.
When walmart screwed up my door though the Check Strap at the bottom of the door (I did not know what it was called until today) shattered and I could not find one in a shop anywhere to replace it.
Well, yesterday, the wind blew the door out of my hand and because there was no check strap to keep it from flying back as far as it possibly could, the door was jerked forward again.
I went back to that website and the gent said to do the same thing I did last time with the socket. The problem is that the wind damage moved the door a Lot further than even that pole did.
With the door closed, you can easily see the hinges in the gap between the door and the front body panel. That means that the door is seated too far out from the door frame. Putting a socket into the hinge and closing the door will only cause the door to move further out from the frame.
Does anyone know of a way to force the driver's side door to seat itself further into the frame? The problem is the hinges are too "open" and each one needs to close tighter but I don't know how to do that.
