locosol96
- March 5, 2007
- Odenton, MD
- 1999 XLT
Hello All! Did a search, and don't think I found anything that sounds like my problem. Driver's door does not open from the inside. The handle can't even be pulled. It's like it's stuck. I can open from the outside, but this is becoming annoying quickly. The locks work 90% of the time, but occasionally the door will lock after I shut it without any help from me, even if the key is in the ignition and running. Also, the outside door handle is a little loose and "flaps" a bit. So, what I can't exactly figure out is: Do I need to replace the actuator? Do I just need the outside door handle replaced? Both? I'm at a loss here. Took the whole thing apart last night and can't for the life of me see what's causing the problem. The door won't open even if I push the rod....
