J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
^ Yes I have. I even posted a picture (somewhere, lol) to make it easier for others to see how it goes in, in the big topic about this.
Since the forum has changed formats, I don't know if I'll be able to find that topic post or not, so I'll just post the pics again. It's bound to be much easier using either miniature needle nose pliers, or forceps. It took me approximately 10 minutes, but I can probably do it again in half that... just takes a little patience.
Grab the long straight portion of the spring with the tool, coil end up, the hook will just go up through the hole at the top, then once the top hook is in, put the bottom hook on the T-shaped piece going horizontal as shown in the pic where it turns from green to blue. You can see the bottom location of the spring on the other doors that it hasn't broken off of yet, at least on mine the driver's door was the first to go and at the time, none of the others had failed yet, but since then at least one other has.
To clarify, this can be done without removing the latch, just looking in with it mounted on the door. These pics are of the new motorcraft driver's door latch I pulled the replacement spring out of.
Edit: Some detail was lost on the above latch pics. Better images in the attached PDF:
