Driver side door lock switch | Ford Explorer Forums
Nunze
Buffalo
96 XLT 5.0L
it locks all the doors,but won't unlock them. passenger side does,and all the other doors work individually. i seem to have power to and from the switch. any suggestions? thanks
That's a new one on me. I'd see how much a switch cost at the junk yard and try it and see what happens.
already did,its not the switch,but thanks
Not a switch, its a wire in the black barrel in between the door and frame.
Look for a broken wire, if its to unlock, it'll be the green/pink if I remember right.
Solder it back together or it'll break again.
excellent! thanks
Had the same exact problem, took me forever to find it.
Do I get to this "black barrel" through the door handle where the switch is or do I have to remove the whole door interior?
Thanks - Kevin
Thanks - Kevin
i'm pretty sure what he is talking about is in the door jamb between the truck and the door where the hinge is
I believe he is referring to the rubber boot that covers the wires. You can see it when you open your door and look between the door and the door jam. I have seen this problem before.
