bobflood
- May 27, 2010
- Powder Springs, GA
- 1997 Eddie Bauer V8 2WD
When i cut open that pink wire, It was corroded and some of the coppers were a dark brown like it had overheated somewhere. Im assuming worst case and that the whole wire may be bad in multiple spots. If I can find where it ends on the other side I may just run a whole new wire.
Questions:
do you happen to have a diagram for it? Drivers rear access panel is where the jack is right? and the numbers for the outer lock keypad? and the splice near the seat, where do i access it from? just the back seat? or do i need to get under the rear seat.
Also! =] where is the ultimate end of this wire in case i need to just run a new one. Is it in the rear access panel? I know there is a computer box or something back there.
Thanks for the Info!
ET: I would first try and just replaced the damaged part you found and see if that fixes the problem. Why go looking for work??
The RAP Module is the "computer box" the number is on in the driver's side rear of the cargo compartment. The splice should be forwrd of that under the floor trim at the outer edge of the carpet under the back door; you should not have to take out the rear seat. I have no physical wire routing diagram, but I have provided access to a site with lots of information below. According to the schematic, the pk/lt grn wire goes from the door switches to the "door unlock relay" in Aux Relay Box #4; that relay box is located somewhere right around that RAP module. Hope this helps. Please let us know how you do.
Auto - Online Repair Info
http://search.ebscohost.com/
PW: rebsco
Work you way down to the schematics.
